Old Jan 11, 2018 | 06:46 PM
  #86 (permalink)
Speedy4x4's Avatar
Speedy4x4
Default Re: 100,000 mile club
Originally Posted by hokkabaz
I just hit the 155K mark!
I was 'supposed' to sell N/A and get an SRT but never had time to do so so I have been enjoying it for almost 6 years (I guess) now. I got it when it had 90 something K miles on. It is my daily drive. Gets driven regardless of the conditions. 30F or 110F, does not matter.
All I have done so far is;
1 set of front tires
2 sets of rears (time for a new set)
So many fog light bulb replacements (glass of the assembly is broken so the bulb keeps braking)
People from this forum suggested the fleece filter& mobile1 0w40 so I have been trying to change the oil at every 5k, max, using only those 2 things.
Glued the rear window (roadster)
Changed the battery
Changed the rotors once and pads twice
Flushed the coolant once. I just emptied it out and refilled it, nothing fancy.
That is all I have done so far.
On the things that do not work section;
2 of the TPMS sensors are dead. Irritating light on the dashboard is on.
Top does not go down due to the leakage from 1 of the pistons. I sometimes fill up the tank which allows me to operate the top for about 10 cycles before it dries up again.
Check engine light is on. I believe the code is p0400 or something similar. I tried to figure it out but failed more than a year ago so I gave up on it.
ohhh I almost forgot! The $%#@ tab that holds the cup holder closed has been broken for couple of years now so it keeps popping out when I go over a speed bump lol
158k for me
Purchased with 50k
Haha, several sets of rear tires
I use external tpms with a display
I flushed mine when I changed water pump, haha
Changed my rotors and pads once around 70k
And keep on all season tires, silverfox has seen snow a few times, some tractor plate weights under my luggage and 285 all season tires and it has surprised me, but mine is a manual not a auto and the rpm control.
