Old Jan 15, 2018 | 06:23 PM
ala_xfire
Default Re: Bow cylinder removal
I am not 100% sure, but I think after the top is released from the bow, there is a rivet down low on either sire that has to be removed in order to fold the top forward enough to access the cylinder pins.
You may also have to remove the weatherstripping at the rear, then remove the 2 rivets that retain the plastic inserts.
