Bow cylinder removal
Old Jan 15, 2018 | 05:08 PM
luckydog941's Avatar
Default Bow cylinder removal
I am in the process of removing all top hydraulic cylinders on my crossfire and am having trouble accessing top bow tension cylinder. My understanding from (Klaus @Top Hydraulics)is that some rivets in the top need to be removed. Please advise of any Youtube videos our other info. Thanks.
Last edited by luckydog941; Jan 15, 2018 at 06:01 PM. Reason: add aditional comments
Old Jan 15, 2018 | 06:23 PM
Default Re: Bow cylinder removal
I am not 100% sure, but I think after the top is released from the bow, there is a rivet down low on either sire that has to be removed in order to fold the top forward enough to access the cylinder pins.
You may also have to remove the weatherstripping at the rear, then remove the 2 rivets that retain the plastic inserts.
stevieb
Feb 2, 2017 08:08 PM
chuck65
Sep 23, 2008 04:50 AM
ZORRO
Sep 17, 2008 11:29 AM
laloggia
Other Cars Etc
Aug 29, 2008 01:17 PM
Midlife
Other Cars Etc
May 13, 2007 12:20 AM
