Old Jan 30, 2018 | 08:19 AM
onehundred80
Default Re: Ignition key gets stuck / throttle cable module
Originally Posted by JustinX
My key is stuck in the ignition. So, if I remove this cable from the back of ignition it will come out? The ignition was replaced by 2nd owner . It all started with rcm. Long story. I pushed the black bolt on upper shift assembly. Thought it was the trans release. Key starts and operates fine. Key was also able to remove before the bolt was pushed. Haven’t been able to drive this car since it was purchased.
I cannot find the screw you pushed and I have no idea what is wrong, sorry.
