My ignition was replaced by previous owner at the expense of almost 2 thousand. I took out the spring and pin thanks to this forum. Left the black cable off, was not allowing key to come out. Problem is in the shifter assembly. I think.
Spring and pin removed. Used Q-Tip to apply green grease inside. Moves like butter.
