Old Feb 25, 2018 | 03:59 PM
onehundred80
Default Re: Remove front center console
Originally Posted by Sennaspirit
hello Massanu,
I was looking for some guidance in removing the facia pieces from my crossfire and wanted to know how you do this. I hesistant to start pulling on things so as not to break them. I need to fix the ashtrayand thus remove that portion of the console . Did you figure out how to replace that piece you posted?
If you have the paddle shifters it an easy task to remove the ashtray module.
You have to remove the center console to get at and remove the four screws that keep the front console tied to the floor. You can then spring the side walls of the console and remove the ashtray. I did it so I know it can be done. I think I pulled the left wall out, moved the left hand side of the ashtray into the console, rotated the ashtray anticlockwise a little and pulled the right side out.
If you do not have the paddles you can saw through the bridge piece as the screws hold it all together. Naturally the radio bezel is taken out first. Look at the paddle shifter install PDF for a look at the bridge and screws.
Remove the radio, remove the two screws at the top of the radio slot. The face plate is pried off, there are four clips on it two at the top left and right and two at the bottom left and right.
Center console removal. CLICK
Paddle shifters install. CLICK
