Remove front center console
Old Jun 19, 2015 | 09:25 PM
massanu's Avatar
Default Remove front center console
Hi Guys
I am working on my project and right now have an issue
I cant find how to remove my current center console (the part in the picture below)
I want to extract it out from my dashboard
I have already remove all the "aluminium" elements of the dash.
Thanks for any help !
Old Jun 20, 2015 | 09:32 PM
JEFASOLD's Avatar
Default Re: Remove front center console
Originally Posted by massanu
Hi Guys
It looks as if you may be breaking new ground here. I have been where you're at several times but haven't removed that piece. Enlarge the photo you posted, see where the fasteners are and work back from there. You may have to remove most of the dash, so take pics as you go, you may do an invaluable service for others and contribute to the database on the forum.
Old Feb 25, 2018 | 01:25 PM
Sennaspirit's Avatar
hello Massanu,
I was looking for some guidance in removing the facia pieces from my crossfire and wanted to know how you do this. I hesistant to start pulling on things so as not to break them. I need to fix the ashtrayand thus remove that portion of the console . Did you figure out how to replace that piece you posted?
Old Feb 25, 2018 | 03:59 PM
Originally Posted by Sennaspirit
hello Massanu,
If you have the paddle shifters it an easy task to remove the ashtray module.
You have to remove the center console to get at and remove the four screws that keep the front console tied to the floor. You can then spring the side walls of the console and remove the ashtray. I did it so I know it can be done. I think I pulled the left wall out, moved the left hand side of the ashtray into the console, rotated the ashtray anticlockwise a little and pulled the right side out.
If you do not have the paddles you can saw through the bridge piece as the screws hold it all together. Naturally the radio bezel is taken out first. Look at the paddle shifter install PDF for a look at the bridge and screws.
Remove the radio, remove the two screws at the top of the radio slot. The face plate is pried off, there are four clips on it two at the top left and right and two at the bottom left and right.
Center console removal. CLICK
Paddle shifters install. CLICK
PNA
Nov 12, 2020 04:44 PM
mattnelson71
Jul 28, 2015 12:52 PM
tom2112
Jul 28, 2015 08:12 AM
MissSilky
Jul 22, 2015 04:28 AM
Rjono
Jul 15, 2015 03:29 PM
