Old Feb 28, 2018 | 02:17 PM
onehundred80
Default Re: New Crossfire '07 Limited Owner
Originally Posted by JCK
I'm going thru the endless links on fixing/replacing things now. lol Thanks, Steve!
180, I see the function for resetting the oil light, but I'm looking for how you access the feature on the odometer itself that tells you how many quarts low you are. You familiar with what I'm talking about? The manual says to just press the odometer stick to the left of the odometer when sitting on a flat surface, wait 7 seconds, and it should tell you this info where your mileage is. All I'm getting is the double wrenches on it though. Could it be that I need to have them reset that function when I take her in for her first general tune up?
Any ideas appreciated!
What the list tells you is how to set the FSS, it is not an oil light reset at all, it refers to the LCD panel that has the wrench symbols on it that you see. Reset it and it should show the oil level.
It does not mention a light at all, you are reading that into the instructions.
