Thread: P0410
Old Mar 3, 2018 | 04:24 PM
onehundred80
Default Re: P0410
Originally Posted by davidricca
Thank you very much for the reply.
I already looked at the RCM and a simple view I did not see anything burned in the Relays. The second step is the blue valve? And if it does not work ??? Anything else?
Thanks again for answering.
regards
There is a grounding wire on the front of the pump and this has been known to get corroded, clean it up and tighten it down again. Maybe you'll be lucky.
