Old Mar 5, 2018 | 05:14 PM
ewaynec's Avatar
ewaynec
Default Re: A/C blows hot and cold at the same time
Awwww, I hurt your feelings. All I did was point out that you were wrong, you are quick to point it out in someone else.
The part you suggested and the one Needswings , suggested is the same and it is wrong. If you notice the two outlet connections are pointing down. On the Crossfire they point out the opposite end from the inlet connection. The hoses are not long enough, nor is there enough room to connect the hoses. It was a simple job to remove the internal parts and put them in the old connector. It is done now and it working fine.
I am glad you did not call me an idiot, because then you would have to eat your words, and if you were a man you would then have to apologize.
