Old Mar 7, 2018 | 08:24 AM
dedwards0323
Default Re: Help. I have an exhaust smell and a p2098 code.
Attached is an explanation of the code you see. Not sure what the issue would be for that description. Hopefully, others on this forum can help.
But I also attached the description for code P209B. That is an EGR valve issue & could explain the exhaust smell you experienced. Make sure you go back & look carefully at the code to identify the code.
