LGV-XFIRE
Just had this issue (freaked out when my check oil light came on, and put too much oil in) the oil pressure indicator is in the trip meter and will display "HI" on it if the pressure goes beyond normal.
That is not an oil pressure indicator, it IS the oil LEVEL indicator. You'll have to drain some out before the level sensor gets jammed (some have reported the sensor jamming after too high a level).
