Old Apr 2, 2018 | 11:33 AM
onehundred80
Default Re: Head light pointing too low
Originally Posted by GeorgeHirata
Zip439, thanks again for this information.
Is it possible that you might be able to take a photo and detail which dia/**** I should be turning to raise the low-beam's height?
Thank you so much.
George H.
The adjusting **** raises the high and low beams together. Get the bulbs located correctly before using the adjustment ****.
There is not much point in having the low beam correct with the high beam aimed at the stars.
