Re: How can I disable the TPMS? (Tire Pressure Monitoring System)
I had my dome light assembly off this weekend, as I was replacing the auto dim rear view mirror in my '04, and had remembered about this little trick that I had read about on here about disabling the TPMS light. However, even though I have read time after time that it is such an easy job, I simply could NOT get the wire to slide out of the harness, even after using 2 or 3 different "pin like" items to depress the top of the pin. Even with the rear view mirror, I ended up having to cut & splice the wires, using wire connectors, like I was swapping out radios in my High School hot rod. I was also a bit leary, since I DO use the garage door opener feature, as it works great! Maybe someone could post a few pics on how exactly they "press down the top of the pin & pull out the wire".
