Old Apr 23, 2018 | 02:04 PM
Kit and Kat's Avatar
Kit and Kat
Default Re: Lost one of our beloved Crossfires
Originally Posted by Ajbarbier
If it doesn't click at all, try disconnecting both of your battery cables. Make sure the positive one is not touching anything, and ground the ground cable somewhere for upwards of a minute. I had the same problem in my N/A, no clicks or anything.
Thanks everyone for the help, we replaced the RCM it wasn’t very expensive, new from CARID..I disconnected the battery, connected the two leads and then installed the RCM, then reconnected the battery. Nothing happened, so I turned the ignition on, put foot on break moved the gear shift to neutral and tried again, it started immediately, and now starts as normal.
