Originally Posted by dinasrt
Just guessing because I haven't seen one of these. Would you loosen and separate the tubes at the midway point and pull the whole lower assembly up towards you?
I wish I could but the flex tube is snaked way in behind the headlight and then down in a very curved way and the filter could never be pulled up to access it.
I suspect I need to remove the inner wheel well to access the clamp that holds the filter to the flex tubing.
Much different compared to the Needswings CAI that was on my Coupe
