Old Apr 29, 2018 | 11:04 AM
DHS's Avatar
DHS
Exclamation Switched Power for VDO
OK, got the underpanel out, gages wired and will start with oil temp. I have one power wire for the two gauges, where is a good place to get switched power? Will run the sending unit wires (2) out to the engine through a port on the left side fuse box.
Found a bunch of broken tabs where the P.O. had put in some stereo, mine now has the stock one in, he must of kept the other, did a s**t job under the dash!
Thanks
Dan
