Old Apr 30, 2018 | 03:18 PM
alexdc's Avatar
alexdc
Default Re: camber kit from f1 fabrication
Originally Posted by DHS
OK, caster or camber? the front lower arm has two bushings, the front lower one can change your CAMBER, the rear will change Caster and affect the camber some. if you want to just change your CAMBER the kit that has the two notched washers is the cheapest easiest to use, there is no adjustability with this, you get what it sets. there is a Utube of this look for it on the Mercedes .
I said caster. They already have a camber arm available. I need a picture. Where do you insert the caster bushing from the k-mac kit?
