The photo is of the FRONT lower "A" arm, the rear bigger bushing is the one that controls CASTER.
Unfortunately they can't fabricate another lower control arm (A arm). He said that it's because it holds the spring.
Do you guys think that I could combine this upper control arm for camber ajustement with the caster bushing in the lower arm for caster ajustement? or should I just do the whole lower arm kit? Or would the eccentric bolt be enough for caster ajustement with the upper arm for camber? I want to track the car. I also want to use it as a daily.
Thanks
