Old May 11, 2018 | 12:50 PM
onehundred80
Default Re: Trunk cannot open!!!
Originally Posted by hamptondude
My trunk would not open so I removed some of the backing behind the seat and used a stick to push the panel out of the way (in the trunk) and caught the release with a wire and pulled it. It broke off. Now I cannot open the top because the trunk panel is down. Is there a way to override the panel switch that allows you to open the top. (I've tried everything short of using a hatchet to open the trunk - removed lic plate lights etc). The panel behind the seat from what I see is not removable without using a welding torch!
2005 crossfire convertible. any suggestion greatly appreciated.
When you removed the licence plate light was that to push the latch mechanism?
You can push the latch inside and it is accessed through the drivers side license plate light hole. There is a PDF on how to do this. It is not my bright idea, I just did a PDF on it. There are a few threads on this issue.
What is the cause of the stuck trunk? Is it air pump problems?
Click on “Index of Crossfire ....” in red in my signature, go to “Body” and look at the bottom of the list there are two PDFs there, look at both.
