Old May 13, 2018 | 09:07 AM
onehundred80
Default Re: engine stalls on acceleration
Originally Posted by Gails car
Thank you for this post, same problem with my 2006 crossfire. The car would not start after a drive. The engine would turn but no igintion, but wait 20 min, car started and off I would go...decided to get "check engine" light. The code said "crank position sensor failure". So i replaced it, but not with a Bosch product. Took it for a drive things seemed fine, but the care started to buck at around 3,ooo rpm and then stalled. Left me on the side of the road till things cooled of, replaced cam position sensor. Car continues to buck and stall...felt like i was not getting fuel? So i replaced the fuel filter, still bucking and then stall, retarts and then a few feet more, stall...
whats going on?
please help.
I would say that you should have used a Bosch part, some of the others do not fit the cars plug and are loose. The cam sensor should also be a Bosch.
When stalled did the engine turnover or was just the starter heard?
Our motto is you either buy Bosch or you walk home.
