Old May 13, 2018 | 10:52 AM
  #1065 (permalink)
onehundred80
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Originally Posted by okilydokily53
Once again, this forum has saved my *** and a bunch of cash. I went ahead and purchased a new ignition lock assembly from my local MB dealer ($154, although they are available for $116 on the web). The install took about an hour and went exactly as the version 5 PDF promised it would. I did have to Dremel off the key buzzer switch.
Thanks to all. Now if I can only find out why my BAS ESP light won't shut up. Yaw sensor? Critter chewed wire? Still working on this one...
The PDF told you how to fix the sticky key problem for ZERO dollars.
The PDF it shows how to use the existing ignition switch.
Did you have some other problem?
