Old May 14, 2018 | 06:15 PM
Gails car's Avatar
Gails car
Default Re: Engine stalls with in the first 30 minutes of start.
Originally Posted by skeet370
Hi Guys,
Hope someone can help, I have a 2004 with 70,000 miles. Early this year I had to change my CPS when the engine would shut down at normal temp. (no problem).
Just this week, twice I had the engine shut off (stall) both times at idle w/ the a/c on and off.
Once I turn the ignition off and turn the key on the car wold run fine all day.
Any thoughts? Oh by the way, no check engine light on at all.
Hi, did you figure out the problem (my situation sounds the same as yours)..was it your non- Bosch CPS part? My code said "change CPS" so i did, but still having problems. I even changed the cam sensor. The more i read from the help I'm getting on this forum, I'm realizing you should never buy anything copied, buy Bosch, Ugh!! What a waist of time and money going the cheap route.
Look forward to your feedback. THANKS
