Old May 18, 2018 | 01:49 PM
onehundred80
Default Re: will not run, help please
Originally Posted by len watts
I laid my 2005 roadster up for a year, just fitted new battery and car will crank but not start. The only way to get the fuel pump running is to manually trigger the fuel pump relay which will start the car for a few seconds. As I have fitted a new battery could there be something influencing the relay other than a bad relay or board
crossfire has done no work just 5000 miles. help
A bad solder joint on the RCM?
You say manually trigger the relay, do you mean continuously or just for a few seconds?
Has a fuse blown on the RCM?
Has a fuse blown in the main fuse box?
