Old May 26, 2018 | 11:40 AM
onehundred80
Default Re: Cannot Disable Alarm
The siren is the round black thing mounted in the middle.
There are NO reservoirs, you are seeing water backup from clogged drains.
BE VERY CAREFUL not to knock the rubber drain tubes off by poking in the drains.
Best bet is the straightened clothes hanger with just a bit of twist on the end.
Very carefully hand rotate it down through the 4 drains.
Blocked drains can lead to expensive problems, that is why I often look at the drains on each side of the car for debris. Any thing I see I try and remove with those four jaw retrieving tools which also have magnet on the end. I just carefully poke it through those rubber combs at each end of the cowel.
Another little tip to remember, I wanted to run some wires through to the trunk. So I taped them to the auto transmission dip stick and poked it through the opening in the bulkhead. They went exactly where I wanted them to go, easier than trying to poke limp wires through.
