spoiler
With much effort, I managed to clear the passenger side drain. The others appear to be holes with no tubes? In the future, I will try to clear without removing the cowl, which may be difficult. I also noticed a rubber grommet with a trap door between the main area and the smaller area near the fender. Not sure what its purpose is.
The alarm is also now disabled and I can now return the fuse to the proper slot. Thanks for the article on replacing the alarm. I may consider that in the future.
The wipers would not budge even with the faucet handle puller, until I took the advice of lifting them. I applied faucet stem grease to the splines to make it easier next time.
There are four drains and you must remove the cowel to do a good job.you have to get rid of all the debris unless you really do not care.
Obviously all drains have an outlet or why would they be called drains?
If they are plugged so badly you still must clear them.
The driver and passenger side drains dump the water behind the fenders and a build up of debris can be found behind the fender, this will lead to rust at some point.
