Old Jun 1, 2018 | 02:52 AM
alexdc's Avatar
alexdc
Default Re: Installation of Sprint Booster
Originally Posted by DTMenace
Chief
Click on the link below and take the advice of the 2nd poster on this tread, easier to go through the console, as opposed to taking the nut off the gas pedal. It is tight quarters for the install. I installed mine back in 2007 and did the install through the console, took less than 15 minutes and still working fine!
The thread is long, but you need to take some time for a review before you attempt the install.
BTW, welcome back to the forum. You should drive to Carlisle this July and meet some of the owners at the Carlisle Chrysler Nationals.
Dennis
DTMenace
https://www.crossfireforum.org/forum...r-install.html
I think the guy who installed it through the console was Eracer76?
This is the thread, he posted on page 8
https://www.crossfireforum.org/forum...st-have-8.html
Here's what he said
I just took the under dash panel out, its two pieced and there is only two Phillips head screws holding it in.
Then I removed the panel on the side of the console, next to the gas pedal, just one plastic phillips screw holding on the vent piece and one regular phillips screw holding on the panel.
With those removed, I just stuck my hand back there and unplugged the gas pedal and installed the sprint booster.
The whole job only took me 10 min tops, but I'm used to taking cars interiors apart, I do it for a living.
The Sprint Booster works good!
Its a bit touchy though, just a little press of the gas pedal and it snaps your head back if your not careful, a least in my SRT it does and I kept chirping the tires around corners by accident.
