Old Jun 6, 2018 | 07:05 PM
Jeff C's Avatar
Jeff C
Default Re: Misfire and backfiring help
Thanks for your help but figured it out today as I started digging into it further. Lets just say if ur not mechanic don’t try to fix car related issues. So I did a soap and water test the other day to see for vacuum leaks and replace hoses and I noticed some silicone which I thought was silicone and heard a bad intake leak, so I replaced the map sensor today and started moving somethings to realize that so called silicone was actually jb weld and there a huge hole patched on the intake manifold actually cracks all over the intake manifold. The mis I thought I had was actually a real bad intake leak causing to much air to be sucked and causing a mis and bad fire. Someone did great mechanic work!!! Off to find a intake. Will post pictures of the intake when I pull it out.
