Old Jun 6, 2018 | 11:12 PM
tighed1's Avatar
tighed1
Default Re: Car wont start. please help
Listen for the fuel pump to run for about 2 seconds when you turn the key to the ON position.
If you don't hear a buzz sound from behind the seats (gas tank) then the fuel pump is not getting juice (Voltage).
Could be the fuse on the RCM but my guess is the fuel relay in the RCM is bad. I can replace that for you.
If you want you can open the RCM and force the fuel pump relay contacts closed then try to start. If it starts you found the problem. I can fix that for you!
If you DO hear the fuel pump, disregard all of the above. :-)
