Old Jun 7, 2018 | 07:24 AM
GraphiteGhost
Default Re: Random Alarm issue and light flashing FIX
This is what you said.
It is the other side that has the CLP/SSM in it.
The sentence before the one you highlighted ( You can also try to cut a couple slices in the rubber plugs under the rear where that cavity is located in the rear ) refers to cutting the rubber plugs under the car. If your lost in this then maybe Maggie isn't. I know the module is in the right side, when Maggie opens it up she'll see that as well. Comprende?
