Old Jun 7, 2018 | 07:48 AM
onehundred80
Default Re: TPMS Receiver Replace?
Originally Posted by go@midnavi.com
I must be missing something. As far as I can tell, it just tells me how to disconnect the wire and disable TPMS. Is the actual receiver above the lamp? I also checked the link for the module you're recommending... After some searching, https://www.ebay.com/itm/TPMS-Receiv...IAAOSw-89ZOMcj seems like it would be the correct part. Wouldn't it? This is a 2004 coup and I don't recall having any HomeLink feature. Maybe the HomeLink device is a compatible replacement?
You do not buy a part using the Chrysler part number, it will have a Mercedes number on the part and they are cheaper to buy using the Mercedes number, find the Mercedes number which will be on the part in the map light, it also is the receiver for the garage door opener.
Not much info is available on this part, no pics to be found.
Last edited by onehundred80; Jun 7, 2018 at 08:04 AM. Reason: Possible wrong number given.
