Old Jun 12, 2018 | 08:31 AM
onehundred80
Default Re: park/fog lights stay on when ign off
Originally Posted by ws6vert
My battery was dead so I charged it up. Not sure why until I discovered that the park lights and fog lights will not turn off after the key is off. Had this car since 2006 and at 53K miles it seem all sorts of things are going wrong..HELP TIA
They stay on after the car has had its lights on and stay on for a predetermined time, they are controlled by the CLP/SSM module in the trunk on the passenger side well under the carpet. It is likely that there is water in the well that the pump sits in. The water damages the pump, usually beyond repair.
Slide a slip of stiff paper down between the foam and the steel body of the car on the passenger side to see if there is water down there.
They probably have been in the ON condition since you had the car lights on the last time.
