Old Jun 13, 2018 | 08:18 PM
pizzaguy
Default Re: RCM or CPS problem
But the pulse module takes an enable from the PCM and the input from the "Start" position on the ignition and engages the starter, when the enable from the PCM goes away (at 400 rpm), the starter cuts out. IF I have no pulse module, how does the starter cut out?
I know the service manual is often not accurate, but....
