Old Jun 17, 2018 | 08:15 AM
onehundred80
Default Re: TPMS Receiver Replace?
Originally Posted by waldig
I deleted the light and have tire stem colored pressure monitors. There are aftermarket sensor systems if you HAVE TO HAVE TPS on your car. I found them a problem and the aluminum stems have failed on 3 of my dodge ram 1500 wheels. ENOUGH! WDY
The Schrader sensor #33500 comes with rubber stems, the aluminum stem is an optional extra that is added prior to installing the sensor, naturally it costs extra.
The universal replacement of the OEM sensors is the Schrader #33500 sensor it is cloned to your existing sensors and the car needs no other resetting.
This system was reported as proven by member Reliable Ron.
This part can replace sensors that have the two wavelengths used in the Crossfire, 315 and 433 MHz.
