Thread: AC shuts off
Old Jun 20, 2018 | 12:22 AM
pizzaguy
Default Re: AC shuts off
Originally Posted by amx1397
check the heater control valves, they are plastic and brake, =AC gets hot once engine warms up
Jim is right, your A/C may not be cutting out, if the duovalve is doing it's usual "stick open" thing, then once the engine gets hot, you have heat, even if the A/C is cooling the air, it then goes thru the heater core and if the valves are open, you get hot air.
The issue can be a sticky valve or valves OR it can be fractured solder connections between the two circuit boards of the climate control module in the dash.
