Old Jun 23, 2018 | 09:08 AM
onehundred80
Default Re: Fuel Filter Issue or ?
Originally Posted by lllouj1
Question all you want. A new filter will do the exact same thing as long as you use the wrong clamps. You have to replace the clamps and use the crimp type clamps that was originally on the hoses. Until then, air will keep leaking past the clamps causing long starts. You can try tightening your clamps but they will eventually leak again until you replace them with a crimp style.
Can you explain why a gap that allows the air to leak into a hose does not leak from that gap with a back pressure of 50 psi on two ports?
With no pressure in the hoses gasoline should leak from that gap, air would not leak in though.
I agree that the crimp style clamps are preferable to the screw type clamp on the small diameters.
