Old Jun 23, 2018 | 05:20 PM
onehundred80
Default Re: Fuel Filter Issue or ?
Originally Posted by lllouj1
Try tightening up the screw clamps to prove my point of an air leak. It should work for a day or two and this will prove my point. Then you need to replace with crimp type. Then we will see whose right or wrong!
The hoses are not a loose fit on the filter so even without a clamp they would not leak air, they would of course come loose with pressure in the hose. If the pressure drops in the system very quickly then the regulator in the filter has failed, it is a fairly common problem which you would know if you did a search on the subject. Replacing the filter with one 5hst does not have the regulator in it will mimic the filter with the totally failed regulator.
You need to tell us how an air leak does not result in gasoline leaking through the same gap.
