Old Jun 24, 2018 | 01:40 PM
onehundred80
Default Re: Cannot Disable Alarm
Originally Posted by mugsy99
I just recently went back under my cowl and re-plugged my alarm.(I had the dead battery/screaming alarm about 4 months ago and replaced the alarm at that time) Anyways, after reinstalling everything the alarm now sounds when I lock and unlock the car. However,The drivers side windshield washer is now spraying directly into the hood of the car. Any ideas guys?? Passenger side works fine!
The nozzle is adjusted by putting a small diameter pin/nail etc into the nozzle hole and moving it to the correct position. It is a ball shape and that is why it can turn. You can also snap open the top of the nozzle housing and remove the ball to clean it and squirt fluid through the line to clear crap out of the system.
If you did something to it though I am only guessing.
I guess people ignored you because you are a Canadian’, we have to stick together.
