Old Jul 3, 2018 | 08:08 PM
Sussudio's Avatar
Sussudio
Default Re: ESB BAS and NO Super Charger
Originally Posted by Joef89
SO tested the IC isn't leaking. Still havent figured it out. checked the wheel speed sensors as someone had said that maybe it was corrosion on the plugs, swapped out the RCM, but no luck.really cant figure out what it may be.
Is the supercharger clutch engaging? If not check the spacing of the shims as if it’s too far apart that could be causing it to cut out.
