Old Jul 7, 2018 | 11:48 AM
onehundred80
Default Re: Engine Performance Problem
Originally Posted by KDW4Him
OK, but the point IS failures. Failure of the pump. We are talking only the SRT6 model so the number made is what? 4000ish?
And I made the comment from a diagnostic point of view. When several other SRT6 owners report intermittent low power symptoms and the fix was the pump and the mileage was 30K or so I would not post the recommendation to change the intake air temp sensor. I wouldn't recommend changing the intercooler. I wouldn't recommend changing the SC clutch. I would go with the common reported problem, the pump.
Equate this Dx mindset of going to a medical doctor for a cough. He doesn't test you for throat cancer first, he goes with the most common cause for the cough. IE the most common post I read for int. low power on an SRT6, the pump.
Reliability of 70K + cars is a different thread.
I corrected my numbers before you posted.
I am making the point that 30,000 miles is not a benchmark figure.
