Old Jul 9, 2018 | 06:11 PM
onehundred80
Default Re: AC/Coolant/Radiator Combo HELP
Originally Posted by Fjp3105
Hey Guys,
My radiator had a leak. I ended up getting a new radiator, installed it as per spec and it seems to be working fine. The car runs, doesn't overheat (the temp gauge shows just a hair above center). Ran the car on day 2 and noticed the radiator light. I checked for coolant, and the coolant is full. I researched hundreds of pages of possible problems but I can't seem to narrow it down.
I turned on the ac and noticed the fan was running. But then I noticed the ac not cooling. Pulled over, checked the fan again and it turns out the fan is not running at all even with the ac on. Does this mean something that tells the fan when to run is defective?
Please help.
Thank You,
FJP
I presume you did not forget to plug the fan in again.
