Old Jul 10, 2018 | 05:02 PM
onehundred80
Default Re: fan control module?
Originally Posted by CapnRon
Ok... bewildered for sure. Fan control module arrived today. No change.
Fuse tested good. Fan tested good. Confirmed working module did not provide a fix.
Checked all other fuses in the box. All good... no fan.
I gotta figure this thing out... any clues...?
The AC control on the console sometimes fails and causes problems. If the fan speed switch is turned all the way to the left, anti clockwise, the AC does not switch on so I guess if this control has failed then the AC and the engine fan could possibly not work. There is a thread on how to make the contacts on this module connect properly. It is a lot of work but might be worth it.
Does the fan work on a hot engine? Maybe I missed the answer to that question as it is an obvious one for someone to ask.
