Old Jul 14, 2018 | 07:24 PM
Fjp3105's Avatar
Fjp3105
Default Re: AC/Coolant/Radiator Combo HELP
Then there is nothing wrong with the fan, it has no intelligence, all it does is spin when voltage is applied.
I think you had best try a fan control module or engine temperature sensor.
youre probably right about the fan. Dropped a new fan in. Worked perfect for a 10 min test ride. Got back and parked, fan sounds like a helicopter. At least it’s not heating up. Then shut it off, started the car back up, fan doesn’t turn on, and if and when it does. It sounds like a helicopter again.... then it slowed back down. So it appears to be working but not 100% when and how it’s supposed to. (The rad light is on and off intermittently throughout)
Where do I locate the temp sensor? And is the module the little box next to the fan where the power for the fan comes from?
Thanks!
