rbracy10406
Got my new servos in over the weekend so I can finally proceed with the project. So far, I did a rough temporary bracket to space them apart and simplified the keyways that I am going to use. I decided to ditch connecting the servos to the ball jonts and connect them right into the female shafts to save about 20MM of space. I worked out how far each damper can turn and the start and stop angles of the open/close positions so it will make life a little easier in the future.
I also started to trace out the front control panel PCB because I wish to eliminate it to save space. There is not much on it so it should be easy to do. If all goes well, I will be able to interface with the back control baord behind that PCB to make everything function. A second reason I want to do it is to be able to pop the front board back on if something were to ever fail.
The white board in the top left of the picture is the one I wish to eliminate. I plan to make a 18 pin connector I can plug directly into the AC controller (green board to the right of it) to emulate the front board. The three blue boards that are stuck together are the 5K digital potetiometers that will be replacing the temperature controls and fan speed. I know the original pots were 4.7K but 5K should be plenty close enough.
You have done some very interesting things so why not put them in their own threads and keep all the information together?
