Thread: Lights
Old Jul 25, 2018 | 04:28 PM
onehundred80
Default Re: Lights
Originally Posted by Burnley Miller
When I stop the driving lights, tail lights and marker lights will not turn off. I am having to disconnect the battery. This started about a week ago. I need help
These lights are timed out by security module in the trunk, do you have water in use the passenger side well in the trunk?
Simply put have you had trouble with water getting into the trunk?
I see you have an SRT, they are fomous for water leaks, through a failed O-ring seal at the base of the spoiler mounts and by waypter getting passed the poor seal around the spoiler mounting.
Water in the well wrecks the security module causing it to operate poorly.
You can slide a taper of paper between the foam and the steel of the well and see if it gets wet.
