Old Aug 1, 2018 | 12:56 PM
Splatfly's Avatar
Splatfly
Default Re: Any body know why
The beeping is controlled by the security pump in the trunk, the siren itself is pretty dumb. The pump tells it what to do.
That is my understanding, do you have water in the well where the pump sits? Stick a taper of newspaper down the gap between the foam and the well side.
Hi and thanks but no water down there had the whole well thing stripped down foam out the lot to see before I found out about the batteries leaking acid. Everything was dry as a bone and no signs of water.
