Old Aug 1, 2018 | 06:32 PM
  #44 (permalink)
onehundred80
Default Re: Cylinder Misfire Help
Originally Posted by jamesmonter2
Guys,
What is the seal called that is attached to the bottom of the engine cover that seals tight to the mas air flow sensor. I cannot find a place to buy this seal. Mine has some dry rot which may be causing a slight air leak. Anyone know where to buy this? I checked ebay but could not find a match. Thanks. Also I have the crank shaft position sensor on order. I will update after I replaced that.
Is this what you are looking for?
