Old Aug 6, 2018 | 09:27 AM
grip grip's Avatar
grip grip
Default Need help with Central Locking.
First off, the hose that runs to the driver's door is leaking I believe, so when I press the lock/unlock button on the dash the pump starts up and times out after a few seconds and doesn't lock/unlock anything. I think I need to replace the door actuator to fix that issue.
The other issue is when I use the remote to lock/unlock the doors, the pump never comes on at all, but the vehicle lights blink indicating the car's receiving the signal from the remote. I checked the two 20 amp fuses under the hood (#25 and #26), but both looked fine. I swapped them out just in case, but pump still didn't try to startup when using the remote. I don't think it's the pump, since it looks new as did the nice pump I bought from Bob that reacted the same when installed.
