Need help with Central Locking.
Old Jan 14, 2019 | 12:46 PM
Default Re: Need help with Central Locking.
Originally Posted by spoiler
I noticed that all of the doors lock when I am inside with the key in the ignition.
Do you still have the problem you posted in your previous post? It sounds like it has been cured.
The doors should lock when the car has just started to move - a safety feature.
Old Jan 14, 2019 | 06:58 PM
spoiler's Avatar
I still need to lock/unlock the door with the key and the hatch is always unlocked, unless driving.
I hear nothing when I press the fob. I have two fobs, one with a newer battery. The lights blink when I press the buttons.
Old Jan 14, 2019 | 10:43 PM
Have you synced the fob to the car? I guess you have at one time.
Does the passenger door lock/unlock when you lock/unlock the drivers door?
Can you operate the locks from the dash switch?
If the locks operate at all on their own then the air pump is working, as the locks only work via the pump.
Old Jan 15, 2019 | 11:31 AM
spoiler's Avatar
I searched the net and tried these two syncs...
-press lock five times for 2 seconds
-ignition to run
-hold unlock button then press panic simultaneously..should hear a beep..programming in effect
-press and release lock & unlock at same time
-remove from ignition-test
And...
-key in ignition-press unlock twice
-turn to accessory within 30 seconds
The only way to unlock the passenger door to lift the handle from the inside.
When I press the dash button, I hear a noise that appears to be emanating from the hatch area.
Thank you for your help!
Old Apr 15, 2019 | 05:10 PM
matabufalez's Avatar
Hello,
Sorry for posting on this post instead a new one, but I think someone can help me with my central locking problem.
After put 2 CR2025 New batteries on the fob, the intermittent lights blink when a key is pressed, but nothing happens.
There was no fuse, so put a 20A yellow fuse and testes again, still not working... The central locking seems dead.
By the way, the passenger Door and trunk does not locks/unlocks by the key, I have to manually open/close the passenger door.
What should I check?
There are two different modules related to the locking, a Delphi unit and the vacuum pump with 3 outputs.
If I got an used unit (Delphi or Vacuum pump?) Will I need pair it with a computer?
What should I replace first? Vacuum pump or electronic next to the pump?
Thank you!
Old Apr 16, 2019 | 07:29 PM
Originally Posted by matabufalez
Hello,
Where did you put the 20amp fuse?
And you DID put the batteries in facing the correct way, I hope.
That is a programmed function, I believe. While the pump COULD be messed up, I think there is a way to set the system up such that ONLY the driver's door unlocks from the FOB (for high crime areas).
Old Apr 16, 2019 | 07:34 PM
The 20amp fuse i belive is Nr 26 fuse socket, I saw it in the paper.
The batteries are correct faced, the intermittents blinks...
I think there is not. An option, it does not locks/unlocks with remonte or key,the trunks also the same.
It seems a K. O. pump, Do I can replace the pump without pair the module with a computer? Taking it from a junk yard and installing it.
What about the Electronic module next to the pump? (Delphi manufactured?)
Old Apr 16, 2019 | 11:01 PM
You have to synchronize the fob with the car security system if the batteries have been dead or removed from the fob for some time.
When synchronized the drivers door, the trunk etc will open, this is the default mode. It can a,so be programmed to open the driver, the passenger doors etc all at the same time.
Synchronize the fob before doing anything else.
Old Apr 17, 2019 | 11:29 AM
Squirrel Crusher's Avatar
Question: Does the Base,Limited and SRT-6 use the same pump? Thanks..Squirrel Crusher
Old Apr 17, 2019 | 11:41 AM
Yes, all the same.
Old Apr 17, 2019 | 08:34 PM
Hello,
Thank you for your reply.
I have syncronize the fob, but I have no results.
I can hear a realy sound (click) when I change locked to unlock or unlocked to locked I can hear the vacuum pump, but none of them close, door passenger,trunk,fuel cap...
I think it is broken, but how can i check it?
Old Apr 17, 2019 | 11:11 PM
Yes, all the same.
Thanks...……….
Old Apr 18, 2019 | 09:18 AM
Hello,
I would first check to see if there is any water in the trunk well I which the pump sits. Slide some paper down the thin gap between the foam and the side of the well, or drill a hole in the rubber plug in the bottom face of the well.
If the pump is working then normally some locks activate.
Old Apr 18, 2019 | 06:49 PM
dahntahn's Avatar
HOw much does this cost to fix at the dealer?
Old Apr 18, 2019 | 08:59 PM
Without knowing what is wrong it is anyone’s guess, do not go to a dealer find a reputable European car repair specialist garage and get an estimate.
Old Apr 20, 2019 | 12:43 PM
Hello,
After disassembly the trunk panels and find water in the tyre repair kit site, I suspected the locking pump could be wet time ago, despite currently it was dry..
Retired the pump from the trunk and opened it to take a look, and of course, it was completely damaged.
I found a pump in a yunk yard, about 75$ so I will buy it this week. I will disassembly the rear wing support and the fuel tank gasket, to look for leaks
Old Jul 12, 2019 | 08:37 PM
dahntahn's Avatar
this may be why my key fob doesn't lock/unlock the door in my car.
ty
Old Jul 22, 2019 | 03:10 PM
  #38 (permalink)
dahntahn's Avatar
does anybody know any around pittsburgh?
Old Jul 22, 2019 | 06:15 PM
  #39 (permalink)
DTMenace's Avatar
Smile Re: Need help with Central Locking.
dahntahn
Below is a listing of independent shops in the Pittsburgh area that service MB products..
Good Luck man, hope you find one to work on your SRT6!
Dennis
DTMenace
https://www.benzshops.com/near/pittsburgh-pa/
Blindeye
Dec 8, 2013 07:15 PM
doggboy
U.K.
Jan 5, 2012 05:13 PM
kolevski
Jul 2, 2009 12:42 AM
Playdrv4me
Jun 20, 2008 08:41 PM
saldous
Feb 24, 2005 04:56 PM
