pizzaguy
Where did you put the 20amp fuse?
And you DID put the batteries in facing the correct way, I hope.
That is a programmed function, I believe. While the pump COULD be messed up, I think there is a way to set the system up such that ONLY the driver's door unlocks from the FOB (for high crime areas).
The 20amp fuse i belive is Nr 26 fuse socket, I saw it in the paper.
The batteries are correct faced, the intermittents blinks...
I think there is not. An option, it does not locks/unlocks with remonte or key,the trunks also the same.
It seems a K. O. pump, Do I can replace the pump without pair the module with a computer? Taking it from a junk yard and installing it.
What about the Electronic module next to the pump? (Delphi manufactured?)
